Found the bad bearing but??
36 A
03-04-2003 19:07:54
The shaft above the pto shaft clutch side was smoked .Now my problem is the outer race has spun in the cover and the thin shim gaskets , there is a few that are shot .What is the end play on this shaft.
Lee
03-04-2003 23:52:11
 Re: Found the bad bearing but?? in reply to 36 A, 03-04-2003 19:07:54
If you are talking about the transmission countershaft, my IT manual says 1 to 4 thousandths of an inch. I would suppose that would be a good clearance for any tapered bearing supported shaft thoughout the tractor. Those kinds of specs are not in abundance from any source, I would suspect.
