2010 front end conversion?
Duallydan
03-07-2003 20:37:07
Is there a way to convert a narrow front to a wide front on a 2010?
Hoosier
03-08-2003 17:55:36
 Re: 2010 front end conversion? in reply to Duallydan, 03-07-2003 20:37:07
We have 2010 with narrow front. Been looking for adjustable wide front for 10 year.My brother found one in salvage couple years ago but didn't pick it up for me. Wanted $1000 and I only wanted to spend $700. Should have sent more money.
MIKE HANLEY
03-07-2003 21:26:39
I don't know of any body that makes a mounting braket to fit a 2010 for a after market WF. Although I would NOT recomend an after market wide front for heavy loader work, one could make over a braket to fit a 2010. It would take some thought, some cutting, some welding and hole drilling. Once saw a 420 T with a Speed Co wide front under it. The bracket was off set to match the off set of the tractor. Didn't look bad. The guy put alot of thought into that engineering. He started with a braket for the 50 to 730. Might be better off trying to find a junked 2010 at a junk yard and buy the wide front.
Duallydan
03-09-2003 13:55:40
 Re: Re: 2010 front end conversion? in reply to MIKE HANLEY, 03-07-2003 21:26:39
Hello Mike. If I could locate a wide front 2010, would there be any adapting necessary to make it fit?
MIKE HANLEY
03-09-2003 21:48:28
 Re: Re: Re: 2010 front end conversion? in reply to Duallydan, 03-09-2003 13:55:40
I sent you an E-Mail.
