2010 troubles
mike
03-08-2003 17:05:52
I have a 2010 diesel that when I changed the hydraulic/trans oil and cleaned the filter, lost all hydraulics. I cleaned the system with kerosene and refilled it with 10w-30 like my manual says and was in the process of working the air out of the lines when everything went dead no hydraulics or power steering. Also when the engine is warm and I idle the tractor the oil pressure goes to 0, but at 1000 rpm I have 25# when warm. until the engine gets to operating temp I have a constant 50# pressure, also I must be getting diesel into the crankcase as my oil level continues to rise by a quart or two everytime I check it. I have changed the oil twice since I got the tractor (two months ago) and I cant find any water in it, I have only worked the tractor two hours and am new to tractors. any help would be appericated. Thanks Mike
Doug Moore
09-29-2003 18:22:15
 Re: 2010 troubles in reply to mike , 03-08-2003 17:05:52
check to see if the split pin is gone out of the shaft that engages the hydrualic pump if it's not that take the transmission top cover off and check the packing nut on big tube at top of transmission on right side sitting in seat. Fuel getting into crankcase sounds like the rubber seal in the injection pump shaftis bad.
Hope this helps.
Doug Moore
