Model AR questions
Johan
03-09-2003 09:42:04
Should the end of the crank shaft be flush with the drive disk when tightened down? I think on mine #266xxx it is not going to be flush. Should the pulley bearing inner washer (retainer)be conical or flat? Thanks.
Clooney
03-09-2003 10:16:05
 Re: Model AR questions in reply to Johan, 03-09-2003 09:42:04
Johan, that drive disk should not pull on flush but should be lacking about 1/8"-3/16" of going all the way on, that way you know it's tight.
~That inner washer should be conical. It needs to be like that for the oil to drain back. Are you referring to the inner washer or outer retainer though.
Johan
03-09-2003 11:20:09
 Re: Re: Model AR questions in reply to Clooney, 03-09-2003 10:16:05
Thank you Clooney. It is the inner washer that I was wondering about as I had not taken it apart myself. The outside retainer is pressed in as far as it can go I suppose?
