1937 A
Tractor Dan
03-09-2003 18:05:52
On my model A the tube that is suppose to push oil to the valve cover doesnt seem to push any oil and if the pipe is removed from governor housing alittle oil will seep but never seems to make it up there
cole in mo.
03-09-2003 23:43:38
 Re: 1937 A in reply to Tractor Dan, 03-09-2003 18:05:52
hey tractor dan, that 37 dosn't have pressure oil to the rocker arms, it only gets oil that is flung around by the crank, timing gears, and the gov. it is flung into a small crevis inside the gov. box then runs down the tube to the valve cover. if the engine is at idle you won't see much if any oil, rev it up and you will see oil run down the tube. those old JDs were made to run at speed, if only used at idle, as in prades and just hacking around, the rockers and valves can guald up due to lack of oil.
Tractor Dan
03-10-2003 04:22:25
 Re: Re: 1937 A in reply to cole in mo., 03-09-2003 23:43:38
thank you
