Diesel Mechanic
Jeff
01-06-2004 14:34:51
Hi Guys, Can anyone recommend A GOOD two cylinder diesel mechanic in central or eastern PA.? I've spoke with A couple of people who I know are good JD mechanics,but they don't want to touch A two cylinder. Thanks
upperpinecreek
01-07-2004 10:33:45
 Re: Diesel Mechanic in reply to Jeff, 01-06-2004 14:34:51
larry deremer 570-494-0441, williamsport, pa, one of the best
jdemaris
01-07-2004 06:07:20
Find your self a good (maybe older) truck mechanic that's worked on two-stroke Detroits. They are (were?) a very common engine. The two cylinder is not much different from a 4, 6, or 8 cylinder. 2-53 is a pretty simple engine. Bigest fear we had at the dealship when we had to work on one was a run-away engine. That's why the engine has a normal shut-off and also an emergency air-choke shutoff. About the only special tool needed to work on that engine is the rack adjustment gauge that matches your injectors. Think I still have a pile of them in my toolbox.
Aaron
01-06-2004 18:25:05
Jeff what are you looking to have done? I might be able to help you out.
Aaron
