Trouble with gears on a 50
Joe
03-15-2003 17:45:44
O.K. on the 50 you know the gears are: 6 4 5 2 3 1 R
I think, I'd have to go out and look.
Well Sometimes I cant get it over to go into 3,5,6. So sometimes all I got is 1,2,4,R. How do I fix it?
MPK
03-15-2003 21:28:39
 Re: trouble with gears on a 50 in reply to Joe, 03-15-2003 17:45:44
On a tractor like that you have to remember to push the clutch ahead just enough to roll the gears a little so the trasmission can shift from low to high or high to low range. Just thought I'd mention it in case you are not familiar with that.
Clooney
03-15-2003 18:25:17
Joe, if you can't even get the lever to move through the crossover gate it sounds like your problem is in the over/under drive shift rail interlock. It doesn't sound like it's releasing when the shift lever tries to move it. With the limited information we have that's probably the best guess & a real good place to start looking for the problem. Once you pull the shift cover & inspect the parts inside you will be able to furnish more information, so maybe then we can make a repair recommendation. Have you tried holding the shift lever all the way up or all the way down while shifting to see if that makes a difference, if it does that will tell us something right there...
