Hydraulic cylinder used on an H John Deere
Jerry
03-21-2003 17:58:37
I am trying to mount a H-1h plow on my 1941 JD "H". I do not know if the cylinder was working or not when I purchased the plow. It was mounted on another non-working tractor. I have hooked up the hydraulic hose to the pump. The other problem that I have is that I don't know whether or not my pump works properly. The cylinder rod is free and there was some old hydraulic oil that ran out of the hose before I hooked it up. The cylinder rod is not presently hooked to the plow. When I depress the lever a small leak develops on top of the cylinder near an adjustmet scew and when I release the lever, oil leaks out on the pump where the hydraulic line connects to the pump. I have since tighten the connection and this has stopped. Any help would be greatly appreciated. Have a nice evening. Jerry
