R Diesel
Jim Snow
03-23-2003 18:20:06
Found a R that supposebly runs sheet metal gone,is sheet metal available & how much is it worth. Thanks Jim Snow.
David from Kansas
03-24-2003 19:47:24
 Re: R Diesel in reply to Jim Snow, 03-23-2003 18:20:06
Jim.
I have most of the sheet metal available for an R at reasonable prices. Where are you located? Some of these items are costly to ship. Thanks.
David
walt
03-23-2003 20:59:00
There is a tractor wrecker in sexsmith Alberta that probably has all the tin you need and they are quite reasonable in there prices. ie: canadian dollars are cheap.
Harry
03-23-2003 19:02:12
Jim: Yes, sheet metal is available but you will have to search for it. Where are you located? The sheet metal will more than likely need repairs but at least you can get some. Also it will be expensive. I have most of the of the sheet metal that surrounds the driver. I am just finishing up with the restoration of my "R", it is a very unique tractor and you will enjoy owning it.
