'46' A-reverse gear question-Help!!
Morgan
03-23-2003 18:33:31
On my 46 A the high-low gear shifter lever doesn't move back to low if I put the tractor in reverse- in other words ,it will go into reverse in high which makes for an interesting ride backwards!! Is there something broken here? Thanks to all who reply!
Clooney
03-24-2003 02:24:45
 Re: '46' A-reverse gear question-Help!! in reply to Morgan, 03-23-2003 18:33:31
Morgan, there is a pin that screws into the overdrive shift fork [inside the trans] that pushes the overdrive shifter into low range when the trans in put into reverse. It has either fallen out, or more than likely someone has removed it. I usually pull it out of mine when I'm into the trans as it makes it easier to shift into reverse. Then I either back up in high range if just for a few feet, or manually shift into low range if I'm backing up very far or backing a wagon..
Morgan--THANKS..
03-24-2003 07:40:49
 Re: Re: '46' A-reverse gear question-Help!! in reply to Clooney , 03-24-2003 02:24:45
Thanks, I thought that maybe something was broke.
