1940 AR
Rudy in Tx
03-23-2003 19:27:07
Does anyone know if you can repair a crack on a head, approximately 2 inches long and 1/4 inch from the intake valve? Also, do you think I can reuse the head gasket which was only on for 2 days
but was torqued down to 125 foot pounds? Thanks in advance and appreciate all the information this discussion forum provides.
Lee
03-24-2003 03:16:11
 Re: 1940 AR in reply to Rudy in Tx, 03-23-2003 19:27:07
Probably can fix the crack, but can't say for sure. Only the machine shop can, but they won't guarantee that either, I don't think. On the head gasket, what's your time worth? It should work if you take it to 150 ft lbs, but 125 is iffy at best. Just might cost you to find out that answer. If you've got more time than money, give it a try, I say.
