420V without sn tag
Jimbo
03-28-2003 18:47:48
Would a none running(possiblely stuck)420V, all original be worth $3,000? Missing the serial no. tag.
G Taylor
03-29-2003 19:59:06
 Re: 420V without sn tag in reply to Jimbo, 03-28-2003 18:47:48
If you can back trace to serial number off the block, try quietly looking for another 420V with your serial number at shows/auctions. Not very many to look for. Plenty of 320/330/420V/430V etc out there built from parts with a stolen serial number plate attached.
Dennis
03-29-2003 10:45:54
Jimbo,
There were 86 420V's built during the total production run of the 420 (Phase I, II, and III). However, w/o a tag how can you be sure what you have?
Dennis
JDAOS
03-28-2003 20:24:05
If the 420 has the original motor you can use the motor number to find the Serial number thru the JD Archives. The number is located on the right side of the motor on the governor mounting casting.
Wayne in Tn.
03-29-2003 06:48:51
 Re: Re: 420V without sn tag in reply to JDAOS, 03-28-2003 20:24:05
JDAOS, the 420V would be a very desireable tractor. The missing serial tag hurts the value to serious collectors tho. Also the replacement tags from Deere are nowhere like the originals.
Any guess at the value w/o the sn tag?
03-29-2003 08:13:24
 Re: Re: Re: 420V without sn tag in reply to Wayne in Tn., 03-29-2003 06:48:51
Have an opportunity to purchase this tractor but don't want to get beat up too bad on it. It would be a fairly easy restoration, just wish it had a tag!!! Jimbo
Wayne in Tn.
03-29-2003 09:48:19
 Re: Re: Re: Re: 420V without sn tag in reply to Any guess at the value w/o the sn tag?, 03-29-2003 08:13:24
I have never owned a (V) but have restored several of the (T) and (W) models. After a nice restoration, they have sold from $5500 to $7500. I don't have the production numbers on a (V) but suspect it is more rare that the (W) and (T) Maybe someone else will post with the production numbers. I would say that to a serious collector, the missing tag would cut the value almost in half. Or some won't even buy a nice restored one with the tag missing. Of course if you are going to keep it to use, it will not make any difference about the tag. One alternative would be to find an original tag at a salvage yard, but I bet that would be near impossible on the (V)
Ray
03-29-2003 17:14:43
 Re: Re: Re: Re: Re: 420V without sn tag in reply to Wayne in Tn., 03-29-2003 09:48:19
A 430V with a replacement tag brought $24000 at
columbia city ind.Wasn't a real good restoration
either.
Dale in IN
03-30-2003 06:30:23
 Re: Re: Re: Re: Re: Re: 420V without sn tag in reply to Ray, 03-29-2003 17:14:43
Ray what day did you see this tractor sell? I was there on Sat and a Nice 430V broutht $33000. I think they said there was only 64 of these tractors built.The buyer was setting just to my left and on the bottom Row. And there was a 330 sold just a head of it for $16000. Also A nice 730D Brought $11500.
Dale Iin IN
03-31-2003 07:33:46
 Re: Re: Re: Re: Re: Re: Re: 420V without sn tag in reply to Dale in IN, 03-30-2003 06:30:23
Correction on the 430V it was $24500.
