JD 950 STUCK CLUTCH PROBLEM
Jerry
03-31-2003 10:31:24
My JD950 has a stuck clutch which I have already tried all the remedies I collected to unstick it, with no success. I need step-by-step instructions on separating of the transmission in order to free the clutch or replace it.
BB
04-01-2003 09:53:35
 Re: JD 950 STUCK CLUTCH PROBLEM in reply to Jerry, 03-31-2003 10:31:24
I recommend you buy a service manual if you intend to do this yourself. I would also recommend the parts manual. The parts manual shows exploded views of all the tractor major parts. You can buy those from JD dealers or by calling 1-800-522-7448. I have a 950 with a stuck PTO clutch. After reading thru the manual, I decided to just live with it as is. At least for the time being. Of course, if it is your drive clutch, you can't do that.
SCOTT
03-31-2003 23:26:11
I HAVE A CLUTCH SET UP (CLUTCH & PRESSURE PLATE) FOR THE JD 950 IT COULD BE A SINGLE ABOUT $175 OR A DUEL CLUTCH ABOUT $425 EXCHANGE.I CAN ALSO SET YOU UP TO TALK TO THE SERVICE TECHS FOR HELP.LET ME KNOW IF I CAN HELP IN ANYWAY.THANKS
