1946 AW Front end stuck...
Morgan
04-01-2003 11:11:38
On my front end, I noticed that one side was extended one hole out from the other side. I tried to slide the other side out but it won't move. I assume its rusted, probably hadn't moved in 50 years, is there a trick to this? Its the round front end.
Bill
04-02-2003 03:48:54
 Re: 1946 AW Front end stuck... in reply to Morgan, 04-01-2003 11:11:38
Ive asked guys about this, your going to have to use heat, a lot of heat, get a big torch tip, heat the casting around axle tube, then throw water on it, they say it works ,I have 2 wide fronts both stuck, some day I will have to try it;;;;Bill
Morgan
04-02-2003 07:20:31
 Re: Re: 1946 AW Front end stuck... in reply to Bill, 04-02-2003 03:48:54
Thanks Bill, I think I will try it,I have a rose bud I can put on my torch. Will let you know! Thanks , morgan
