JD 630
Miss/Cross firing
Joe S.
04-03-2003 11:18:47
Starts up and runs OK cold. Once warmed up and placed under a load - starts miss fire or both fire at once - resulting with no power. The load screw is wide open. Cap looks good on the inside - no gray marks.
Joe S
04-04-2003 06:56:35
 Re: JD 630 - Miss/Cross firing in reply to Joe S., 04-03-2003 11:18:47
Thanks for the help. Sending the brother to the shed to work on the suggestion.
DON
04-03-2003 14:30:43
CLOONEY IS RIGHT ON BUT IF THIS TRACTOR HAS BEEN IDLING AND RUN ON LIGHT LOADS ALL WINTER I'D PUT IN A NEW SET OF SPARK PLUGS. WE HAD THIS PROBLEM WITH CUSTOMERS EVERY SPRING. DON
Clooney
04-03-2003 12:14:05
Joe, a little more information on when the problem started & how long it's been acting up will help us get you closer to the problem.
~Try a couple of things to see if you can point us down the correct path. ~See if running with the choke partially back on helps the problem, if so you are probably fighting a carb problem, or lack of fuel flow to the carb.
~Then feel the ignition coil when it's acting up & see if it's too hot to touch, if so you probably have an incorrectly wired or missing ballast resistor. If the coil is hot & you have a volt meter see if the coil power side terminal is running over 8 volts [engine running], if so you have resistor problems.
~If the plug wires are still in the conduit tubes pull them out as they might be cross firing in the tubes.
~Make sure your spark plug wires aren't automotive TVRS resistor wires but are solid metal core wires..
~Another thing to look for is that the exhaust manifold heat valve is set at EXACTLY hot or cold & not in between.
~Post back with a little more info & we can get you real close to your problem..
