1520 JD governor problem?
Steve
04-07-2003 20:14:01
My 1520 gas engine speed will not stay constant under load, especially between 800-1300 rpm. Also whenever the throttle is increased the engine revs to a high speed then settles down. Especially with a cold engine. Could this be a governor problem and is there a way to check out the governor to confirm it without tearing it all apart?
Thanks for your help!!
