1952 A FAN bearing making terrible noise
wilson5
04-16-2003 13:15:47
I have an A that is making a terribel grinding noise at the FAN. I took the fan belt off to make sure it was not the Generator or water pump and it is not. I also check for play in the fan and there was none. I tried putting grease in through the pipe plug at top but noise is still bad. How can I fix this noise???
Ralph
04-16-2003 19:48:46
 Re: 1952 A FAN bearing making terrible noise in reply to wilson5, 04-16-2003 13:15:47
I had the same problem last year. One of the fan clutch facings had disintegrated. My noise was intermittent, sounded like the fan was working the shroud or radiator over. A continuous squeal would probably indicate a fan bearing. Took fan shaft off. now might as well check the gov. Okay, might as well grind the valves. A few more bolts and we honed the cylinders and a new set of standard rings.
