JD's with duals
01-08-2004 17:28:58
Does anyone have any photos of john deere two clyinder tractors with dual rear wheels? I you do could u please post them.
Thanks
Grnghost
01-09-2004 21:29:03
 Re: JD's with duals in reply to ., 01-08-2004 17:28:58
Have posted a picture under the tractor photos of my 1939 G on Factory duals. Have a tractor like this for sale and have posted it in the picture ads. Need to get rid of it the wife says. Too many!!! Can't imagine why she said that???
buckeye al
01-09-2004 18:22:53
Wish I had pics of our little H when we had duals on it. H axles are long enough we simply put on another set of wheels & tires. Didn't matter how muddy the woods got, it would roll right through! Often mashed down the ridges left by others or non dual trips making the woods trails actually smoother. Was a bit comical looking but effective! Couldn't pull a hen off her nest in snow though. Rears rolled up on top but fronts would plow through till the rears spun out, dug a hole & you were stuck.
easydoesit
01-09-2004 06:50:05
I have a unstyled G, A, and B with 40 inch duals on the rear. I removed the G and put the skeleton steel back on for now. I am getting a digital camera today and maybe I can put some pictures up when I figure out how. May have to get directions.
highgrove
01-09-2004 05:40:48
I have a 38 L ,the original manual that was shipped with it and a set of dual wheels on it. The manual gives instructions for installing them and tells you to remove one of them and turn the wheel to use the single bottom turning plow.
Jericho
01-09-2004 04:19:22
A friend of mine puts duals on his 60 every year. Last year, due to the strange weather here in MI, he had duals AND chains on at the same time. That old 60 sure looked mean! I will try to get some pictures to post.
CDM
01-08-2004 19:12:00
POSTED A COUPLE PHOTOS OF MY 830 WITH DUALS ON THE TRACTOR PHOTO GALLERY
MIKE HANLEY
01-08-2004 18:00:56
I posted a picture of a 1958 JD 620 that we got in 1966 and had till about 1970 in the TRACTOR PHOTOS in the left hand side of this site. We had this tractor when we rere renting my wifes uncle's farm in Juneau County. It had duels for two reasons. There were some wet bottom land on that farm. When you got stuck with this tractor with the duels, YOU WERE STUCK!!! The other reason we had on the duels is that in the back ground you can see a FARMHAND F-11 loader. We had a 10' haybasket for the loader and used it to stack loose hay in large hay stacks. Some of the hay ground was on hills and I wanted extra stability on the hills with the haybasket on. The duels were mounted by mounting a casting on to the axels and then the steel wheels of the duels bolted to those casting. I thionk there were made by M&W. Thats me and the dog we had had at that time in the picture
MIKE HANLEY
01-08-2004 18:05:18
 Re: Re: JD's with duals in reply to MIKE HANLEY, 01-08-2004 18:00:56
That tractor is still in Juneau County and is still working. My brother-in-law has talked to the guy about selling it,,,but no sale as of yet.
