2010 Tractor Value?
2010
04-24-2003 16:17:15
I am about to look at a 2010 Deere to use as a little utility tractor. What would the value of one in good working order be? Gas and Diesel as I don't know yet which it is. Thanks.
JDknut
04-24-2003 17:20:56
 Re: 2010 Tractor Value? in reply to 2010, 04-24-2003 16:17:15
I&T 2003 Used Tractor Price Guide: $2260 to $5800 depending on condition (Fair to Excellent), year (1962 thru 1965), and whether gas vs diesel. some people are down on the 1010/2010 because of the "sleeve-and-deck" cylinder arrangement their engines used (all cylinder sleeves are fused at the top into a common deck) which sometimes caused coolant leaks into the oil because the bottoms of the sleeves were hard to seal, especially with the Diesel. They are harder to get parts for, too. But if you find one that runs good now, then it must be one of the surviviors so if a good deal and you like it, go for it.
excuse the long post, just my $0.02
good luck
Henry J
04-24-2003 16:29:32
2010
Don't forget to engage the pto when you look at it. I know where one is that looks good, but has a nasty growl in the pto drive and the motor sputters around that has not sold for a long time. Good Luck
