41 John Deere-B Head Question?
2 cylinder
04-28-2003 06:30:16
I have a 41-B and was wondering if it would be likely to have the Flat Style Head, and if it doesn't, will a Flat Style Head bolt onto a 41-B? Thanks in Advance.
WTW
04-28-2003 12:47:53
 Re: 41 John Deere-B Head Question? in reply to 2 cylinder, 04-28-2003 06:30:16
NO and NO, There were two different flat heads used on the row crop model "B". 1938 and older was one and 1939 and 1940 was the second. All BR's were flat and was one or the other of these two. The third head was not flat and was used from 1941 through 1946. The next two later heads will fit and are used for replacement but are not flat. The only flat head that will fit your tractor is an aftermarket Heisler. The bolt patterns and water holes on the John Deere flat heads are different than the non flat heads.
