2 CYL 830 PTO
BOB GRAY
05-02-2003 11:55:32
Can a PTO system be installed into a tractor that does not have one factory installed. Would like to know how many hours labor it would take and if the parts would be able to be found used Any help would be great
Gpower
05-02-2003 12:22:48
 Re: 2 CYL 830 PTO in reply to BOB GRAY, 05-02-2003 11:55:32
To the best of my knowledge the gear box for the pto was installed in all the R-830 tractors, due to the fact that they have live pto, and the gearbox for the pto also drives the transmission pump. Also you could have powr trol without pto. All you have to do is get the shaft, 2 couplers, linkage and controls, the correct pto and hyd back cover and install it. The cover will bolt right on. I have all these parts if you are interested in pursing this. Just let me know and Id be glad to help out in any way I can. May look at a 830 parts book and get the part numbers, I can check them with the parts I have as well. I have everything you would need. Good Luck
Gpower
