JD 60 Block
jm4020
01-09-2004 20:36:07
Just wondering if anyone can tell me if a block out of an A is the same as the one for a 60
Mike Aylward
01-10-2004 10:05:57
 Re: JD 60 Block in reply to jm4020, 01-09-2004 20:36:07
JM4020, the answer to your question is "yes and no". The 60 takes an A4320R block which was later used as a direct replacement for the late A's. The late A's (s/n 648,000 and up) originally used an A3703R block which looks identical to the 4320 block with the exception that the 4320 block has two bosses on the bottom of the block that are tapped for bolts to bolt up through the frame on the 60's. These simply are not used on the late A's. The 3703 block will physically bolt to a 60 crankcase but there will be no bolt holes on the bottom to run the bolts up through the frame. Any block out of an earlier A will not physically bolt up to a 60 and vice versa. Hope this helps. Mike
jm4020
01-10-2004 10:21:40
 Re: Re: JD 60 Block in reply to Mike Aylward, 01-10-2004 10:05:57
thanks for all your help
jm4020
01-10-2004 08:24:04
cylinder block
buickanddeere
01-10-2004 06:57:40
Cylinder block or crankcase block?
cole in mo.
01-09-2004 23:36:16
blocks from the late styled As are the same.
