Pin and bushing that attaches yoke to transmission housing?
'66 4020 load d
05-10-2003 16:25:50
I will be replacing the leaking load shaft seals on the 4020. I have never replaced the pin in front of the yoke that attaches the yoke to the transmission housing. Is there an allen screw that holds this pin in place? Is this a straight forward process of pounding the pin out and then the bushing? Any suggestions on how to remove the bushing and pin if it is not that simple of a processs will be appreciated.
Mike J
05-10-2003 18:33:25
 Re: Pin and bushing that attaches yoke to transmission housing? in reply to '66 4020 load draft yoke ?, 05-10-2003 16:25:50
That pin is a pressed in pin. The hole in the bottem is to hold the bushing in to take the pin out use a 5\8 grade 5 bolt hold it with a vise grip hit it hard with a hammer they come out easy that way if you try to use a punch they will bounce and they just don't work as well as the bolt will. Then the bushing is held in by a 1\4 in. roll pin take that out then you might have to drive the bushing out also.
Mike J, thanks for the info.
05-10-2003 23:04:17
 Re: Re: Pin and bushing that attaches yoke to transmission housing? in reply to Mike J , 05-10-2003 18:33:25
4020
