'48 B Trans. Problems
sundance43
05-12-2003 14:09:26
Hi, I can't get the transmission on my '48 B to go into Reverse, 1st, or 3rd. gear. It won't go into the slots on the quadrant. The tractor has been sitting under cover for almost two years.
Thanks,
Mark
Clooney
05-13-2003 04:05:53
 Re: '48 B Trans. Problems in reply to sundance43, 05-12-2003 14:09:26
sundance43, it sounds like maybe a shift shaft is frozen up with rust or it is still in another gear & the shift lever won't move that far over.
~About all you can do is pull the trans top cover & see what is causing the problem. You should be able to move the shift shafts with a big screwdriver. You will also be able to see if one if still stuck in gear....
sundance43
05-14-2003 05:30:37
 Re: Re: '48 B Trans. Problems in reply to Clooney, 05-13-2003 04:05:53
Thanks Clooney. That's what the problem was, Rust. Now it works like a charm. Thanks again.
Mark
