2010 injector pump problems
Oregon Mike
05-18-2003 16:06:37
My 2010 recently started loosing oil pressure, I changed the oil and pressure went to 50psi. Over about an hour it dropped to 25psi, another half hour down again to 0-5psi. I was confused and rather frustrated. I checked the oil level and found it was 1+ quarts overfull. I checked the radiator and the level has not changed. I am assuming it is the injector pump seal on the bottom. I would like to know if anyone can think of another problem, or if anyone can give me information on how to remove the injector pump without screwing up the timing. I have a IT shop manual but that thing is even more worthless than my tractor. Any information would be appericated. Thanks.
Mel
05-18-2003 20:31:31
 Re: 2010 injector pump problems in reply to Oregon Mike, 05-18-2003 16:06:37
Turn the motor over till it is on TDC. you have to look on the pump side for the little hole on the clutch housing. If you remove the pump, don't turn the engine over till you replace it. There should be a little plate on the pump held on with 2 small screws. Remove it and check to see if the timming marks line up. When you put it back in turn the pump as far counterclock wise as you can and then clock wise till the marks line up. It should be close then.
