1942 A
sam
05-19-2003 15:00:11
just got me a handstart A, noticed it has no dipstick to check the oil..im kinda new to john deere!!! can someone tell me where to check the oil and how many quarts it holds?? thanks, sam
MPK
05-20-2003 21:29:51
 Re: 1942 A in reply to sam, 05-19-2003 15:00:11
I believe your A will hold 10 or 11 qts with the filter. I have a 41 A which would be the same.
dwm
05-19-2003 18:32:27
Sam,
There will be a test cock on the right side behind the pulley down low. This is the oil level in the crankcase. After draining, it will probably hold 8 to 9 quarts with a filter change. I would strongly recommend you get at least an operator's manual. A parts and shop manual are also recommended. Good luck...
