1020 pressure control valve
huntingfool
05-24-2003 10:41:27
Leaking hydraulic oil around pressure control valve housing. any ideas what may be the cause? Thanks in advance
davidval
05-25-2003 00:27:41
 Re: 1020 pressure control valve in reply to huntingfool, 05-24-2003 10:41:27
if you mean the steering priority valve (which is named pressure control valve in the books and is located with 3 bolts under the right footrest), then there are 2 'o' rings under it that maybe dry or broken. if you remove the valve, there is a 5/16" drilling in the housing behind the valve into the transmission. be ready to collect the oil.
david
