1946 B backfires when starting
Joe
06-01-2003 10:23:30
my tractor is rebuilt, ran like new. I rebuilt a carb for a friend and test ran it on mine, well ever since that, mine powers out on the road, didnt before, and about every other time i start it, it backfires really really loud. What could be causing this, i didnt mess with any adjustments on my carb when it was off. I cleaned the plugs, and helped a little. What could be the problem?
thanks
Clooney
06-01-2003 18:56:57
 Re: 1946 B backfires when starting in reply to Joe, 06-01-2003 10:23:30
Joe, if you turned that carb over when you had it out there could be dirt in the main nozzle side holes. You might want to pull the float bowl & main nozzle to see if there is dirt floating around in there....
