B cylinder head removal
Jim Hammel
06-01-2003 14:54:47
Is there an oil line INSIDE the engine crankcase that has to be disconnected before removing the head on the Mod "B"???
Ran across an old post (Jan 2001)about removing the head on a B and the question was ask if the rear oil line connector was disconnected. Also said it was tough to get at. This led me to believe it was inside the oil sump, since the oil line connector (mounted on the head) feeding the rocker arms is an easy access.
Could use some good advise again, don't want to mess this old girl up any more than she already is. Thanks, Jim H.
JeffPA
06-01-2003 20:35:09
 Re: B cylinder head removal in reply to Jim Hammel, 06-01-2003 14:54:47
Jim,
No oil line to remove to take off the head except the one to the rocker arm. I know because I had to remove my head twice. The second time was because I thought you could put the frame on the tractor with the head on. Live and learn... By then everything was hooked up and buttoned up in the crankcase.
Aaron
06-01-2003 15:06:00
Jim, I just did a 43 B and dont remember any oil lines to the head but there is one to the block that you have to get to through the crankcase cover.
Good Luck
MPK
06-01-2003 20:27:19
 Re: Re: B cylinder head removal in reply to Aaron, 06-01-2003 15:06:00
I believe the only one is to the rocker arms under the valve cover.
Jim Hammel
06-02-2003 01:18:37
 Re: Re: Re: B cylinder head removal in reply to MPK, 06-01-2003 20:27:19
Hey thanks a lot for the feedback, Its a relief to know I can pry the head loose without tearing up anything else. Jeff, I don't know what to say, that must have been a real sick feeling when you realized ya had to take her back apart again, bet ya won't do that again.
Thanks guys, your inputs have removed my jitters.
Jim H.
