What oil to use?
Jeff
06-06-2003 18:45:30
I have a 1944 A. It has a single hydralic outlet and I am unsure whick oil to put back in it when I do an oil change. Does the rearend and hydralic system use the same oil? I think the engine oil should be 30 weight but I am unsure about what to put in the rear. I appreicate any and all help.
Jeff
F-I-T
06-07-2003 14:37:06
 Re: What oil to use? in reply to Jeff, 06-06-2003 18:45:30
Jeff:
You can order manuals direct from Deere publishing, you can call 800-522-7448. Have a credit card handy.
Frank-in-Tallahassee
70D // 855
Another Jeff
06-07-2003 06:34:06
Operators manual says for the transmission to use a straight 90W under 32 degrees and a straight 140W over 32 degrees. I've found the seals can start to leak and drip when I put 80-90 in mine. Did not want to split the tractor to replace the gasket so put in the 140 weight and never had a problem since. Your John Deere dealer has reprints of the original manual and they are kind of invaluable.
52BMAN
06-06-2003 19:01:11
I use 30w oil in the engine, 80w-90w gear lube in the transmission/rearend, and straigth non-detergent 30w in the hydraulics/power-trol. This is what the operators manual says to use. Any other questions on this, just email me, I'll be glad to help.
Jeff
06-06-2003 19:10:38
 Re: Re: What oil to use? in reply to 52BMAN, 06-06-2003 19:01:11
THANKS for your help.
I am new to this old tractor stuff so please bear with me. I know where to add both the enginge oil and pow-trol but where do you add the rearend oil?
52BMAN
06-07-2003 13:18:47
 Re: Re: Re: What oil to use? in reply to Jeff, 06-06-2003 19:10:38
The rear end and transmission gear lube goes into a large hole that is just behind the rear axle on the right side. It has a 1 1/4 or 1 1/2 inch plug with a square head on it. This is the fill for both the differential and transmission. They have seperate drain plugs underneath. Hope this helps.
