Oil filter on JD-B
Joe McGinnis
06-06-2003 21:37:47
Am working on a B and have not had any luck replacing the old filter. Feel kinda foolish but just can not get the new filter to fit snug enough. What is the upper end of the filter stud attached to? When I try to tighten the big nut on the filter bottom it feels as though the upper end of the stud is loose. Have never been far enough into the "oil system" to understand all the happenings. I have the I&T shop manual but cannot visualize what happens. What is the best approach? Do I have to remove the pump and filter assembly? Any suggestions or advice will surely be appreciated. Thanks and God Bless Joe*
Bill
06-07-2003 17:35:12
 Re: oil filter on JD-B in reply to Joe McGinnis, 06-06-2003 21:37:47
got a 49 B that had the top filter casting broke, was one of the nastiest little fixes I tackled in awhile,youll get hands and arms all cut up ,plus use words you probably forgot you knew, Good luck and at least youll get to clean up the bottom of the crankcase, sometimes youll find all kinds of neat stuff in there<<<<<<
Clooney (slow loading pic
06-07-2003 04:33:55
third party image
Joe, you could have a problem there. That oil filter stud runs up through the oil filter body [#3] & attaches [threads into] the oil filter head cover [#8]. ~The other thing that sometimes happens on those old 2-cylinder Deere's is the filter body [#3] starts to crush & bend if the cover nut [17] is overtightened.
~If your problem is a broken filter head or bent body top it is quite a job to repair. It's not too bad if the crankshaft is out but is a real pain if you have to work around the crankshaft.
~The first thing to do is MAKE SURE you don't have 2 gaskets [14] under the bottom cover [15] as that will cause you a big problem. ~To get the filter head off you will have to pull the filter outlet [#7] down, an old 5 gallon pail handle works good if it is bent a little so it will hook in the holes in the side outlet holes. Once hooked in the holes a hammer of piece of pipe can be slammed down in the handle to pull the filter outlet down & out.
~Probably the place to start is to identify where your problem is then post back with it's location & we can guide you through the repair...
Joe McGinnis
06-07-2003 20:43:27
 Re: Re: oil filter on JD-B in reply to Clooney (slow loading pic, 06-07-2003 04:33:55
Had planned to get a quick fix idea from you folks --but no go on this one. Do appreciate your info but am going to postpone this project for a week or so. My 80 year old knuckles cringe at what lays ahead. Does one work through the plate on the top of the engine {connection rods etc.} or is there another approach? As you can see I am in total limbo on this but do welcome the challenge. Thanks to all and God Bless you.
JoeM.
Bill
06-07-2003 22:47:23
 Re: Re: Re: oil filter on JD-B in reply to Joe McGinnis, 06-07-2003 20:43:27
joe I went threw the top, I also pulled the govenor housing too, it helped me see in there a little better, I dont have the wisdom like most on this site, weak mind strong back, so I always look for what I think is the easiest way to go, usually ends up taking longer though, there aint much room in them Bs to work easy, Grandpa said it was like tring to get your hand down a frigid girls dress, just aint easy----- ---????? Good Luck,, Bill
