14-30 wheels
RonMC
06-08-2003 23:27:29
Hi - It's been a while, but I need your expertise again. Can someone tell me if the 14-30 wheels used on the styled D and the 60 standard are the same ? I have a wheel and it looks identical to the others on my D, but would like to know if there is some small difference my weak eyes can't see ? Thanks, Ron
C Butler
06-09-2003 06:46:33
 Re: 14-30 wheels in reply to RonMC, 06-08-2003 23:27:29
It appears that the AD2636R 14x30 wheel was used on the styled "D" & all the 60-620-630 & 70-720-730 std tractors. This is a revelation to me as I've been looking for one for quite a while, & thought they were unique to only a few of the sytled "D"s. This will enable me to widen my search, or if you have an extra, or know where I could find one I'd sure appreciate an email.
RonMC
06-09-2003 07:08:02
 Re: Re: 14-30 wheels in reply to C Butler, 06-09-2003 06:46:33
Thanks for the info - nice to know it's OK. I have 5 wheels all together, but 3 are fairly rusty on the outside from calcide leaking out the valve. They are useable, but would take some work. One of the options I had considered before I got the 5th one was to have a couple of wheels sliced and welded - just have to grind the weld nice and smooth and finish it before painting. A welding shop I asked about this job said it would be no problem to do, so you might consider this route. I'm heading for Saskatchewan at the end of this week and will keep my eyes open as to what's laying around and let you know. Just e-mail me direct so I have your address and I'll let you know when I return about July 2nd. Ron
C Butler
06-09-2003 09:50:20
 Re: Re: Re: 14-30 wheels in reply to RonMC, 06-09-2003 07:08:02
Your email address seems hidden as is mine. I really don't like to post where everyone can see, but In this case I guess I'll have to. My address is cbrepair@netins.net By the way you started me thinking & I checked my 4010 manual & guess what-they also use that same part# for the 16.9x30 tires! By inference I would also expect that a 3010 & 30&4020's would also be the same. If you find anything on your trip, I would be very interested. Thanks in advance. CB
RonMC
06-09-2003 22:08:06
 Re: Re: Re: Re: 14-30 wheels in reply to C Butler, 06-09-2003 09:50:20
Got the address, Wow ! what a bunch of machines all using the same wheels - now you got me thinking, maybe I could find some much nicer ones ! I looked for a profile manager as my e-mail hasn't been blocked by ME, but maybe someone can tell me how to straighten it around - I'll keep my eyes out for wheels, talk to you after return, Ron - Just found the block, never had to click the box after address before, but should be ok now.
