730D Sheet metal
John L.
06-10-2003 22:46:29
I bought this 730D and the hood has been replaced. I doesn't fit well. HoweverI have noticed others that don't fit well either and they look like original parts. The roll in the rear of the hood doesn't fit the steering casting. Also, my hood is bolted with bolts with washers that don't fit well and expose part of the hole. Were there special fasteners used to hold the hood down?
will
06-12-2003 06:14:01
 Re: 730D Sheet metal in reply to John L., 06-10-2003 22:46:29
you can get a complete hardware kit that fastens your hood, grille, flywheel cover, and dash pannels from Correct Connection. It cost around 40 dollars, but is well worth it to have all the original washers, springs, bolts etc. They are very helpful and polite. Their phone is 814-926-2777. They are located in Rockwood, PA. The best of luck with your hood.
John L.
06-12-2003 21:41:57
 Re: Re: 730D Sheet metal in reply to will, 06-12-2003 06:14:01
Will, thanks for your post. This thing has been bothering me more than I wanted to admit. Have been holding up the paint work because I knew it wouldn't be right.
