2010 starter
M Young
06-17-2003 17:42:43
Ive been having my share of troubles with my 2010, Today I went out to start it to turn around to work on the injector pump. It would not turn over and the ground on the battery started smoking. I cleaned off the terminals put a small amount of grease on the terminals, tightened them down and tried again. This time it cranked very slow, i figured it needed charging and did just that. An hour later I tried to start it again and it cranked very slow, then started to speed up to normal cranking speed. I then noticed smoke spewing out from the starter. What is going on? Does this indicate a bad starter? or did my pressure washing weeks before get it wet. Thanks
