John Deere 111 Carb problems
John Touchard
06-23-2003 07:43:29
I cleaned out my carb on my 111 and now it takes about 15-20 seconds of cranking before it fires up. any info on how to correct the problem?
Handsome Jim
06-24-2003 15:17:59
 Re: John Deere 111 Carb problems in reply to John Touchard, 06-23-2003 07:43:29
I'm no mechanic John, but I had the same problem several years ago. The longer it sat the harder it was to start, and if I didn't start it at least once a month thru the off season, it wouldn't start at all without squirting gas directly in the carb. I replaced the diaphram in the fuel pumping mechanism. Seemed to remedy the problem. HJ
Fred G
06-23-2003 09:20:40
Is the choke working - cable adjusted properly, etc? Does is start right away when warmed up? Sounds like you're either getting no choke, little choke or else have a mis-adjusted float. If the power is good and it operates normally when warmed up, try adjusting the choke and/or verifying the choke is functioning.
John Touchard
06-23-2003 13:47:16
 Re: Re: John Deere 111 Carb problems in reply to Fred G, 06-23-2003 09:20:40
Yes the tractor starts up great when warm, just the initial start. Someone mentioned that the carb bowl might not be holding the fuel in it. What do you think about that?
Thanks
