JD A Main Bearings
John Staub
06-23-2003 13:59:59
My engine was knocking badly and I found one of my connecting rod nuts were loose and one half of the main bearing gone. I assume it was ground up instead of the previous owner just leaving it out. Otherwise everythign looks beautiful, much better than I expected. Here's my problem: I need a set of main bearings, I believe Deere p/n AA397R, and the dealer wants $190 per set of two halves. Plus, I need four shim packs, p/n A303R, and they are $35 each! There must be a mistake because I could have bought a whole rebuild kit with sleeves and pistons for $450. Can anyone recommend a good place to get the bearings and shims? I appreciate any advice.
M Horne
06-23-2003 19:19:55
 Re: JD A Main Bearings in reply to John Staub, 06-23-2003 13:59:59
I have NOS AA397R main bearings and they are cheaper than JD Thanks Mike
John Staub
06-24-2003 04:02:25
 Re: Re: JD A Main Bearings in reply to M Horne, 06-23-2003 19:19:55
I did some more research. My left piston rod is p/n A2344R and it is the one without bearings. I thought the bearing was 1/2 there but there was none left. The right piston is A4648R and it has the bearing halves A4659R and looks good. The I&T manual & the JD parts manual say some had babbitt bearings but aren't clear which. Could I have had babbitts on one side and it disintigrated?
Any suggestions? It looks to me like my best bet will be to find an A4648 rod and get new bearings. Anyone have a spare? I appreciate any other help or comments you have.
Thanks! John
M Horne
06-24-2003 19:29:32
 Re: Re: Re: JD A Main Bearings in reply to John Staub, 06-24-2003 04:02:25
You're talking about ROD bearings not Main bearings ,there is a great price difference in the two.Yes you could have babbit on one side.The easy way to tell is that babbits have shims under the cap,inserted ones do not.
