John Deere Tractor 1010 Special Transmission Probl
John E Hargrove
06-29-2003 07:40:20
Knock in transmission which knocks in-gear or out-of-gear anytime clutch is out.
Have torn down once and did not see any damaged gears. Sounds like it is toward the back axle.
What turns back there when nothing is in gear that would make it knock?
Loren
06-29-2003 16:04:00
 Re: John Deere Tractor 1010 Special Transmission P in reply to John E Hargrove, 06-29-2003 07:40:20
As you know if you watch this board much, there are very few 1010 fans, so it isn't likely you will get a lot of response. I have a 1010 but like many others I see posting here, haven't tackled any major repairs on it. I would, however, be interested in what you learn when you solve your problem if you don't mind coming back and posting the solution.
Heat Houser
06-30-2003 02:32:31
 Re: Re: John Deere Tractor 1010 Special Transmissi in reply to Loren, 06-29-2003 16:04:00
I am not familiar with the 1010 but could it be the PTO bearings/gears causing your knock?
