2010 hydrolic pump problems
big mike
07-01-2003 13:33:34
I have a problem with my 2010 3pt hitch hydrolics. There is no pressure, arm won't lift, it works only for a short time, oil circulates fast in the transmission. Any help would be appreciated.
Lloyd
07-02-2003 11:16:07
 Re: 2010 hydrolic pump problems in reply to big mike, 07-01-2003 13:33:34
Was it working o.k. prior? or has it been this way, the pump is in the middle of the tractor, also might check to see that the lever under the clutch pedal is in the correct position and not flip flopping around,give us some more details. Lloyd they also have a large screen on the right hand side(barrel shape) which needs to be cleaned from time to time and may work o.k after sitting and then get worse-
big mike
07-03-2003 07:53:27
 Re: Re: 2010 hydrolic pump problems in reply to Lloyd, 07-02-2003 11:16:07
we took top off and put new tube in, new o-rings put back together worked find , guy drove it about a mile up the road and brought back and said it quit working we have no power steering or 3-point hitch hydrolics and there is no pressure in plug on the side of the transmission but the oil in the bottom of the crankcase churns real fast all the time. Big Mike
Elton
07-13-2003 15:31:03
 Re: Re: Re: 2010 hydrolic pump problems in reply to big mike, 07-03-2003 07:53:27
Clean or replace the screen/filter on the side of your tranny, at the bottom. If you are not sure you want to spend the $60, remove it and run without a few minutes to see if that is your problem, which is common in these tractors.
