1958 720 Gas Changing Axle / Trans Oil
Gerry
07-02-2003 14:47:59
Hello All.. I am changing the axle and trans oil. The book calls for about 8 gallons in the trans/axle and 1 and half quarts in the first gear reduction. I drained 15 gallons out of the axle and trans. It looked like coffee with cream. I understand the color but 15 gallons..... Should I put 15 gallons back in?? I found the level plug and will start to refill tomorrow. Any comments are welcome. Thanks.. Gerry
Clooney
07-02-2003 15:04:16
 Re: 1958 720 Gas Changing Axle / Trans Oil in reply to Gerry, 07-02-2003 14:47:59
Gerry, the milky look means there is water in the trans oil. It's possible all the extra 7 gallons is water but it's also possible some of it is engine oil from a leaking R/H main bearing oil seal leaking inside the 1st reduction cover..
~You should probably start by just changing the trans/rear oil [you only fill it to the the check plug threads, about 7.5-8 gallons]. Then check it occasionally to see if you are gaining oil, if so you probably have a leaking R/H engine oil seal...
Gerry
07-03-2003 05:19:40
 Re: Re: 1958 720 Gas Changing Axle / Trans Oil in reply to Clooney , 07-02-2003 15:04:16
Thanks Clooney. I do watch the engine oil. It has a dip stick and doesn't move. This is a trcator I picked up last fall and just getting the oil changed and starting to put hours on it. Thanks again.... Gerry
