1 stripped head stud
stripped stud
07-03-2003 14:46:51
on my tractor i just rebuilt a JD A i was putting the head back on and torqued all my head bolts to the right specs and when i got to the last one i was torque in it was stripped is this bad if it is only just one or should i pull the head off and fix it thanks
ChuckW
07-03-2003 20:16:41
 Re: 1 stripped head stud in reply to stripped stud, 07-03-2003 14:46:51
why can't you back the stud out and put another one in. I believe you could weld a nut on then let cool and back the stud out. Use two nuts locked off to put the stud back in. I suppose there is enough of the stud exposed to do that.
davidval
07-04-2003 02:23:24
 Re: Re: 1 stripped head stud in reply to ChuckW, 07-03-2003 20:16:41
if the stud is long enough and there are enough threads left on it to hold a nut, you may try a thick washer to reposition the nut. (preferably hardened washher).
david
dwm
07-03-2003 18:04:17
I know it's not what you want to hear, but the stud problem needs to be fixed. You don't want to chance blowing a head gasket.
Ben.So.Tex
07-03-2003 17:10:57
It may cause your head to warp/ are get water into the engine and cause you some bigger problems,You may be able to retap the thread to a size smaller and put on a nut to match the thread,. My two cents, Good luck Ben
