Why is my battery boiling over ??
Jerry C OK
07-06-2003 11:48:27
Re-phased the subject,1949 JD B, 12 Volt battery is boiling over(checked for leaks).Pulled batt, out of my MF 65 (neg gnd) put in JD B (pos gnd)KICKER is it's only hooked to starter. All other wiring has been removed (future wiring project)
ANY HELP IS APPRECIATED Thanks Jerry C
lc
07-07-2003 06:03:16
 Re: Why is my battery boiling over ?? in reply to Jerry C OK, 07-06-2003 11:48:27
I had 68 Cutlass olds one time do that. New battery solved the problem.
buickanddeere
07-06-2003 19:44:03
Besides a failed battery. Too high system voltage 13.8V 70F+, 14.2v at 32F and lower and 14.5v below 0F. Over voltage results in high currents, gassing, over heating. Over filling,vibration and high ambiant temps will make a battery slobber too. Running a lead acid battery over 80F shortens it's life.
Dave
07-06-2003 17:55:08
Charging voltage too high...overcharging
Bob
07-06-2003 19:08:03
 Re: Re: Why is my battery boiling over ?? in reply to Dave, 07-06-2003 17:55:08
If I understand Jerry correctly, he does not have his charging system hooked up.
Jerry C
07-06-2003 19:51:20
 Re: Re: Re: Why is my battery boiling over ?? in reply to Bob, 07-06-2003 19:08:03
Bob, You are correct, charging system is not hooked up
and it only happens when it sets for a few days ???? Jerry
David Bacon
07-06-2003 21:35:45
 Re: Re: Re: Re: Why is my battery boiling over ?? in reply to Jerry C, 07-06-2003 19:51:20
I have never seen a battery do this unless it is over charging. If this is the case and you do have the charging system hooked up---(this perhaps does not pertain to this situation) The very first thing you should do is tap on the voltage regulator, usually a fairly sharp blow. The contactors are welding themselves together is the simplest way of explaining it. Good luck Dave NE Iowa
David Bacon
07-06-2003 21:44:59
 Re: Re: Re: Re: Re: Why is my battery boiling over in reply to David Bacon, 07-06-2003 21:35:45
Sorry but did you have a draw from the starter? Does it spark when hooking battery post up? (BE CAREFULL AS YOU MAY HAVE TO HAVE SOME ONE READ THESE POSTS FOR THE REST OF YOUR LIFE IF THE BATTERY EXPLODES) A draw or short could maybe make it boil. I will keep thinking on this one and post back if I get any other ideas. Try unhooking the battery post and see if it still boils. Dave NE Iowa
Bus Driver
07-06-2003 13:18:45
A frequent cause of boiling is overcharging. With the tractor running, place a voltmeter across the battery terminals. If the voltage is 15 or higher, it is overcharging. Another cause is a loose internal cell connector- the 12 volt battery has 6 internal cells. That condition usually results in one or 2 cells using lots of water while the others do not. Battery replacement is the cure for loose internal connectors.
may be the answer Jerry
07-07-2003 10:02:35
 Re: Re: Why is my battery boiling over ?? in reply to Bus Driver, 07-06-2003 13:18:45
I dropped the battery about 2" when I installed it 1st time cells shorting one another may be it but it still starts tractor a week later
David Bacon
07-08-2003 19:20:34
 Re: Re: Re: Why is my battery boiling over ?? in reply to may be the answer Jerry , 07-07-2003 10:02:35
Just a note on batteries----A friend of mine used to work at a battery manufacturing Co. His job was to take batteries returned to the factory (defective ones) and repair them. The way they fixed most of them was to drop them hard on the work bench. If I have my story straight a small chunck of lead would be laying across the plates. Thus -- smacking the battery down hard would jar it loose, then settle to the bottom. While on this subject my second cousin who worked in the same factory decided what brand of batteries they were making for the day by the stencils he took to the assembly line with the fork lift. Dave NE Iowa
Bob
07-06-2003 12:30:52
Defective battery... try another battery.
AZ Jack
07-09-2003 21:46:02
 Re: Re: Why is my battery boiling over ?? in reply to Bob, 07-06-2003 12:30:52
Since you do not have any charge going to your battery and it is still boiling over-I would almost guarantee your battery has served most of its useful life. It may work for you however for quite some time-the biggest problem is the mess and the chance that you may ruin your battery box. Jack
