1952 JD A rear wheel slips on axle
wilson5
07-07-2003 13:27:00
My JD A rear wheel keeps slipping in on the axle. I can not get it to stay put. any suggestions would be greatly appreciated.
Robert
07-08-2003 08:38:24
 Re: 1952 JD A rear wheel slips on axle in reply to wilson5, 07-07-2003 13:27:00
I had the left wheel move in on my '45 A. I jacked up that side, and found that the bolts were unevenly tightened. I went back and retigtened them all a little at a time until they were all the same. Being that the hub is tapered, it could be that the bolts aren't all drawn up evenly.
Just a thought.
Ralph
07-08-2003 08:20:11
My brother's left wheel on the A kept creeping out with the #8 mower until I bypassed the 1/2 and 3/4 drive sockets with extensions and got in with the original wheel wrench supplied with the tractor. As far as I know it hasn't moved since.
ChuckW
07-07-2003 19:32:24
Wilson, I found that the splines need to be dry, no penetrating oil or never seize. Also have had to change the center and the collar, also make sure you use plenty of force on the collar bolts. A good cheater on 3/4 drive socket will help.
Clooney
07-07-2003 14:51:27
wilson5, there are a few different methods to keep that wheel from moving. The one that works best for me is to insert a strip of .015"-.020" thick tin between the wheel hub & the hub clamp before tightening the clamp. That usually puts more pressure on the hub & keeps the wheel from migrating..
