GM changing the look UNSTYLED
36 A
07-10-2003 19:30:18
I bought a 47 gm in rough shape.Hood ,grills, even the dash isnt worth anything and the radiator is bad accept for the bottom tank that has a pump in it.1 Just woundering if a unstyled pedistle will fit the frame.2 will the bottom tank fit the open radiator.I just think i could build a cheep unstyled G with 6 speed ,water pump,eletric start.
520-LP
07-11-2003 20:10:48
 Re: GM changing the look UNSTYLED in reply to 36 A, 07-10-2003 19:30:18
36A according to the parts book the front end support[frame]is the same
Eric
07-11-2003 11:57:16
For what it's worth, I've seen a straight six speed A with an unstyled front end, but that doesn't answer your question regarding a G.
