1010 Timing Mark Location
Rasty
07-14-2003 18:32:40
Wanted to set the timing on my JD1010 gas but cannot find where the timing marks are located. The I&T manual shows it under a cover on the clutch housing on the left side of the tractor, but my tractor doesn't have the same setup. Any help would be appreciated.
Loren
07-15-2003 13:26:06
 Re: 1010 Timing Mark Location in reply to Rasty, 07-14-2003 18:32:40
I saw a post on another board that may help you. It says with reference to a 1010, "The light should light on the '26' mark on the flywheel. The timing hole is just under the battery and left of the distributor."
