1010 gas problems
Sighombre
07-14-2003 20:47:34
My 1010 gas runs fine somedays, other days it quits 3 or 4 times every 4-5 minutes, after it gets hot, then, if you get it to start again, it will run fine the rest of the day, or act-up again an hour later. Recently, I am having a tough time getting it to start. I put a new distributor cap and spark plugs in it last year and cleaned-out the sediment bowl last week. Thanks!
Loren
07-15-2003 06:24:48
 Re: 1010 gas problems in reply to Sighombre, 07-14-2003 20:47:34
My guess is that you have an easy fix. Take off the gas line fitting that goes into the carburetor. Behind it and inside the carb is a fine strainer. I found mine completely packed with what looked like fuzz. Remove that strainer and take a look at it. Could easily be your problem. It is a little difficult to get it cleaned out if it is packed, but do it carefully and you can get it clean without tearing it up.
