power lift wont STOP LEAKING
36 A
07-17-2003 19:40:36
I just replaced the 2 packings on the pto on my 39 Band it still drips out the rear end drain..Ive replaced everything i can think of .2inner packings#a668r,outer sealaa2296r,the cup but not the gasket not aviable but the old one was in good shape.What is left.Im gona sell here pretty soon!!
Clooney
07-18-2003 03:23:47
 Re: power lift wont STOP LEAKING in reply to 36 A, 07-17-2003 19:40:36
36A, are you sure the leak isn't coming from the rockshaft cylinder to rear housing gasket? Does the rockshaft bleed down with a load on it? If so suspect that gasket.
~If the rockshaft doesn't bleed down try running the PTO for a while, maybe the inner packing hasn't conformed to the cup yet.
36 A
07-18-2003 04:33:28
 Re: Re: power lift wont STOP LEAKING in reply to Clooney , 07-18-2003 03:23:47
I put the cup on new and that took care of the saging.But now if i dont make sure the handle is right it will drop.Is there any way to adjust this.It has one peddle and a bent lever to.
the new packings looked like rubber and didnt feel as snug on the shaft as the old ones.is that spring going to press them enough.thanks
