Deere trivia question
Joe P.
01-16-2004 05:30:42
Which 2-cylinder Deere had the largest, heaviest flywheel?
Ralph
01-16-2004 19:55:42
 Re: Deere trivia question in reply to Joe P., 01-16-2004 05:30:42
You guys are going to make me reweigh the late A flywheel I bought last summer? I thought it was worse than the wheel weights I put on the 820. Maybe its because one can get a such good grip on those ring gear teeth.
Bob-Wyo
01-16-2004 14:30:13
I would have to say the big double wide flywheel on a W-113 (D engine) used on a pumping unit.
Bob
Now Hart Parr had a tractor with a 1100# flywheel.
Robert Burdine
01-16-2004 11:58:38
The 830 John Deere
Kevin
01-16-2004 11:08:45
It also is just a guess (not weighing either), but having worked with the unsytled G and the Waterloo Boy. The Waterloo Boy was a heavier flywheel.
Farm w/Junk
01-16-2004 10:06:55
I would say the G with 2 flywheels welded together they talk about on the pulling board.
Matt
Chuck Bales
01-16-2004 16:09:15
 Re: Re: Deere trivia question in reply to Farm w/Junk, 01-16-2004 10:06:55
Hey Matt, I saw that too.Maybe I'll weld another flywheel on my 830! It does make me wonder what will happen when I hit the nitrous button though?
Duane Larson
01-16-2004 10:03:34
Joe P.
The flywheel weights can be found in the Master Parts Index - the AR1104 80-830 flywheel weighs 225.00 lbs, the AF2194 720-30 flywheel 185.43, the AF689R G 181.35, and the AD852R D 145.00.
I don't know the weight of a Waterloo Boy flywheel, so Clooney could be right.
Any of them are a good reason to wear your steel-toed sneakers when pulling them off.
Bob
01-16-2004 12:21:55
 Re: Re: Deere trivia question in reply to Duane Larson, 01-16-2004 10:03:34
Do you have weight figures on the "R" and the "80" diesel?
Duane Larson
01-16-2004 13:30:44
 Re: Re: Re: Deere trivia question in reply to Bob, 01-16-2004 12:21:55
Bob,
For the R, flywheel AR426R weighs 214.10 lbs, and the 80-820-830 all use the same flywheel so the number for 830 works for the 80. In fact, all 4 tractors seem to have the same casting number for the flywheel, R1304R, so differences may be due to the different ring gears.
Deere Heaven
01-16-2004 09:22:56
I would have to guess a Unstyled G OR D
JD 5020 guy
01-16-2004 07:21:21
My guess is a 830 or D.
Clooney
01-16-2004 06:29:26
Joe, just a guess as they are all heavy... Possibly the "Waterloo Boy" tractor…
