How to disconnect back up RIO on LT160 JD.
Joe
08-02-2003 14:23:02
What is the best way to disconnect the RIO back up on a John Deere LT160 without causing any problems with the electronics to the machine.This is a very annoining problem that I never had on any of my previous JDs. Thanks for any help.
Joe.
John51
08-02-2003 16:42:16
 Re: How to disconnect back up RIO on LT160 JD. in reply to Joe, 08-02-2003 14:23:02
Is it a hydro tranny? If so, when you step on the reverse pedal the linkage in the rear of the tractor pushes against a switch that shuts off the deck. It is somewhat adjustable, but I took mine and turned it so the rod doesn't ever hit it and turn the thing off. Look at the right rear, just behind the axle, mounted on the frame and you should see it.
kimMarengo
08-27-2005 20:18:17
 Re: Re: How to disconnect back up RIO on LT160 JD. in reply to John51, 08-02-2003 16:42:16
Thanks for the tip. But I just got a new one tonight and after looking where you said I just unpluged it and that seems to do it to. I was wondering though how you un plug the seat so you can get off with out the engine shutting off. Thanks for any help you can give me.
Kim
Joe
08-02-2003 17:17:55
John51,That sounds great, Thank You for your help.
Joe
Fred G
08-03-2003 16:02:02
 Re: Re: Re: How to disconnect back up RIO on LT160 in reply to Joe, 08-02-2003 17:17:55
I bypassed mine on my 335, but kept the parts, if I ever sell it I will put RIO it back to stock. Otherwise you open yourself up to a possible lawsuit if the next owner is injured.
Just make sure you keep the parts..... .
Junk
06-26-2004 13:35:36
 Re: Re: Re: Re: How to disconnect back up RIO on L in reply to Fred G, 08-03-2003 16:02:02
I have a GX335 also and am looking to disable it. How did you do it?
Junk
