52-A noise in engine - don't know where or how to
Jim M (RI)
08-04-2003 09:42:44
Hi,
Just bought a 1952 "A" that starts and runs fine but has a very loud noise. The noise is almost like when a starter doesn't disegage but I don't think that is the case. I am a novice and stuck as to what to do. The oil pressure looks good, so it doesn't seem like an oil problem. Any ideas or suggestions would be greatly appreciated. I don't have a clue at this point.
Jim
Robert
08-04-2003 09:54:08
 Re: 52-A noise in engine - don't know where or how in reply to Jim M (RI), 08-04-2003 09:42:44
Just a thought, but if it sounds like the noise is coming from your starter,or in the area of the starter, could it be that the flywheel shield is either bent, and rubbing on the flywheel, or perhaps something has gotten between the flywheel and the shield (like dirt, an old screw/bolt)? There's not a lot of room between the flywheel and shield (at least on my '45 "A), so if there's anything in there, it could be the source of your noise. You might also check to see if all the bolts are tight on the shield....
Good Luck, and hope this helps!
