JD 730 Front Weights
2CYL GUY
01-16-2004 18:42:55
I am looking for the original front weights for a 730 diesel. Also what is a reasonable price?
MIKE HANLEY
01-17-2004 08:50:35
 Re: JD 730 Front Weights in reply to 2CYL GUY, 01-16-2004 18:42:55
We have one 730D with a factory set of 5 weights and one 730D with a reproduction set that is mentioned below and you can't tell the differance.
buickanddeere
01-17-2004 08:50:09
Combine rear wheel "style" rim weights can also be used on tractor fronts. Part # AB5564R which consisted of two 100lb castings #B2016 were listed for the 720/730. Something worth a 2nd look when seen at shows. I even have a set one of the 110's. They don't quite fit right and require the wheels to be dished out. Sure hauls the lawn roller. Saves carrying the weight on the axle bearings/splines/hubs.
Danny Berryman
01-17-2004 06:46:05
Know a guy that has a original 3 piece set off 630. Think they are the same. He was asking $600 for all three. Located in NC. let me know if you are interested as I will see him tomorrow
720Deere
01-17-2004 05:25:29
I think that you will soon find that there is nothing reasonable about the pricing of original JD Front weights for the 730. A three piece set brings from $500 to $750. If you are looking for function more than "being correct", there are some pretty good aftermarket weights available. A full 6 piece reproduction set can be had for around $750 and the 4 piece for around $465.
